Cold air intake AEM
Ce forum est verrouillé; vous ne pouvez pas poster, ni répondre, ni éditer les sujets.   Ce sujet est verrouillé; vous ne pouvez pas éditer les messages ou faire de réponses.    Team-Kmikz Japan Drive Index du Forum -> Achats et Ventes -> Ventes Terminées
Bowers
MessagePosté le: Ven 30 Jan 2009 - 13:32    Sujet du message: Cold air intake AEM Répondre en citant
Citation:
A Cold Air intake system relocates the filter outside of the engine compartment to deliver the coolest air inlet temperatures possible. Cooler air carries more oxygen, which translates into a more intense explosion in the combustion chamber to create more horsepower and torque. But that's only part of the power equation. Tuning the inlet pipe in length and diameter to match the engine's resonance helps move more air to the cylinders (think of your engine as a big air pump), and this tuning allows us to deliver the maximum power gains throughout the entire RPM range. We also monitor fuel trim correction factors and all OBDII sensors during R&D to eliminate leaning the engine out and/or throwing a check engine light.
Our Cold Air systems are dyno-proven and tested against the competition with the goal of creating more useable power than any other system of their kind. Every AEM Cold Air induction system features the highest standards of construction and we are so confident in their fit and performance that we guarantee them for the life of your vehicle. All AEM Cold Air systems include a lifetime DRYFLOW Synthetic air filter and come with a limited lifetime warranty.
Engineered to produce maximum horsepower and torque
Manufactured and assembled in the USA
Inlet constructed of lightweight 6063 aluminum and mandrel bent for maximum flow
Reinforced TIG-welded brackets and fittings deliver added durability
Utilizes a complete hardware kit with soft mounts for a guaranteed perfect fit
AEM’s lifetime DRYFLOW Synthetic air filter is up to 99.52% efficient in FINE DUST testing, filters dirt as small as one micron, and never needs filter oil!
Comprehensive installation instructions, and decals included
Available powdercoated in red, blue or silver, or with a mirror-polished finish
Guaranteed for life
CLICK HERE to view the results of our DRYFLOW's Filter Efficiency Test w/fine dust between a new and cleaned filter.
CLICK HERE to view the results of our DRYFLOW's Filter Efficiency Test w/coarse dust.
We EXTREMELY abused one of our Synthetic DRYFLOW Air Filters with brake cleaner, window cleaner, industrial cleaner, bleach, Honda Brite, carb cleaner, weld prep and topped it off by blowing the filter out from the inside with 125psi directed air stream... Then sent it back for independent testing to see how efficient the filter would be. CLICK HERE to view the test results!
Voila pour ce qui est du système !
Alors tout neuf valeur 350€ vendu 180€ non négociable ( moitié prix déjà) le fitre est un K&N.
MessagePosté le: Ven 30 Jan 2009 - 14:37    Sujet du message: Cold air intake AEM Répondre en citant
bonne vente pour du top matos Okay
Bowers
MessagePosté le: Ven 30 Jan 2009 - 14:42    Sujet du message: Cold air intake AEM Répondre en citant
top matos Okay
ouaip ça c'est vrai !
MessagePosté le: Ven 30 Jan 2009 - 15:02    Sujet du message: Cold air intake AEM Répondre en citant
sa vas sur nsx                                         Arrow          très loin                 Arrow
bonne vente Wink
Bowers
MessagePosté le: Ven 30 Jan 2009 - 23:10    Sujet du message: Cold air intake AEM Répondre en citant
Eh rigole pas ! c'est un carbu ?
Bowers
MessagePosté le: Dim 8 Mar 2009 - 22:34    Sujet du message: Cold air intake AEM Répondre en citant
Toujours a vendre ?
ballernumber13
Véhicule(s): Honda Civic ej9
MessagePosté le: Dim 15 Mar 2009 - 14:57    Sujet du message: Cold air intake AEM Répondre en citant
je me trompe peut etre mais c'est pas un modele pour ej9 ?
mizuma san
MessagePosté le: Dim 15 Mar 2009 - 15:11    Sujet du message: Cold air intake AEM Répondre en citant
si si Okay
Bowers
MessagePosté le: Dim 15 Mar 2009 - 18:24    Sujet du message: Cold air intake AEM Répondre en citant
oui oui !
niko974
Véhicule(s): ej9
MessagePosté le: Lun 29 Nov 2010 - 19:11    Sujet du message: Cold air intake AEM Répondre en citant
tu livre a la reunion ?
MessagePosté le: Aujourd’hui à 03:52    Sujet du message: Cold air intake AEM
Ce forum est verrouillé; vous ne pouvez pas poster, ni répondre, ni éditer les sujets.   Ce sujet est verrouillé; vous ne pouvez pas éditer les messages ou faire de réponses.    Team-Kmikz Japan Drive Index du Forum -> Achats et Ventes -> Ventes Terminées Toutes les heures sont au format GMT + 2 Heures
